Hi! Thats what we have been doing but the CORS network in our area has been going through some changes and has decreased in reliability. We want to bring it in house.
First of all, thanks for such a detailed description of your workflow! It’s always of great help for troubleshooting when we get such thorough info.
To me, such behavior looks like something went wrong with the base position setup. So I’d really like to clarify the steps of the base setup in more detail.
Did I get it right you averaged the base position while being fixed? How did you save the base coordinates?
Just to double-check if there is any issue—if you average the position in Single, will there be the same wrong baseline in 19 km?
Shouldn’t you be setting the base on your fixed point, then from the base get the corrections from your CORS? Record the those coordinates. Plug them into the base as a known point still set up on your fixed point. Then use your rover getting corrections from your base, eliminating the CORS now?
When you average the base (instead of using accurate known coordinates) it’s offsetting everything there on out.
I don’t have a known point, so I am creating the known point for base from the CORS network and then eliminating CORS. I got it to work this morning so not sure what happened yesterday.
I see you’ve resolved your issue but I just want to confirm details of your workflow for obtaining / creating your own “known point”.
You set your base up and initiated logging for that position for something like an hour (or whatever period of time).
You took the observation file and ran PPK on it using a CORS base to obtain an “accurate” coordinate for that position OR you used OPUS static processing to obtain an accurate coordinate for that base.
You then took those coordinates (E.g. lat, long, ellipsoid) and manually enter it as your base coordinates; thereby creating your “known point”.
I ask because you didn’t really go into specifics with regards to how you were obtaining your “known point” and this is likely where the issue would be identified.
