I’ve looked around the forum at similar posts/issues but haven’t found a solution yet.
I have not been able to get NTRIP over bluetooth to provide corrections with my iOS device, status is stuck on single and message is “waiting for corrections.” If I create a hotspot the corrections work and switch to “fixed”. Ideas?
I just updated to 30 beta 3 and I’m using iphone 13 pro max with latest OS (16.2). I’ve double checked that my login info with my state system (MNCORS) is correct. I’ll attempt screenshots below
I’ve just tried the same configuration with RS2 on 30 Beta 3 and couldn’t reproduce this behavior. The receiver gets corrections with the NTRIP over Bluetooth option. But I’ll help to figure out why it doesn’t work for you correctly. Can you please tell me what version of the app is installed on your iPhone? Is it the latest one?
In my experience the issue has always been operator error . Ensure Wi-Fi is not enabled. Connect to Reach Via BT, change settings to NTRIP over Bluetooth, Ensure your credentials are correct, and that there are no scheduled or unscheduled NTRIP outage. One time I was positive my unit was broken, and what had happened was my NTRIP provider decided to de activate one of my accounts. Good luck! Also I’m ashamed for saying this, but have you tried turning everything off and back on again with the proper settings
You phrased your response just right to get me to connect the dots. My login information worked on the provider webpage but needed me to combine two seperate login fields (organization and username) when connecting on the device. I had contacted the provider to ask about network issues and was able to figure that out talking with them.
I’m not sure how I got connected over the hotspot - I had been trying with multiple devices and deleting and resetting login info so I may have had it right at one point and deleted it.
