I noticed this behaviour after flashing v2.3 firmware and updating the Reach to v2.9.1.
When the Reach is configured to output the position via Serial port in NMEA format, it doesn’t handle NTRIP corrections via Wi-Fi (VRS - RTCM3). The ReachView Status screen becomes choppy and laggy and it loses the float / fixed status. The base correction log shows a data dropout during this period, but the the raw data appears to be correct.
After changing the output coordinates format (or disabling position output), it recovers float / fixed status and ReachView returns to work smoothly.
Is anyone else facing this issue with the v2.9.1? In v2.7.4 and previous versions (v2.3 firmware) it worked well (I didn’t tried the v2.8.0).
I own only a Reach and use it as rover to record raw data and base corrections (connecting it to a 3G Mobile Wi-Fi modem).
I need a 9600 baud output rate, but at 4800 the issue is still present. I will try another RTK solution (FKP or MAC) that does not depend on sending rover NMEA position to the server, as it could be the cause.
About other configs, base mode is off and RTK settings are:
I use Continuous and also Galileo system.
Here is link to serial output setting. Other then that i dont use VRS and has ntrip via www.rtk2go.com The RTK boat project
I am no sure what version i run, need to check this
Yes, when outputting NMEA data, the Reach stops recording NTRIP corrections (no FKP, no MAC, no VRS). Turning off the position output, it works well (after a restart).
I just tried to change the update rate to 1Hz and it also works, but that’s a bit slow for photogrammetry.
Bug confirmed, will try to fix asap. For now the problem will occur if the device is configured to use USB-to-PC and the output is not being read. Also with UART on low baud rates.
I had the same issue using GPS and SBAS at 14HZ. Everything works out until for 10 minutes or util you start to inject corrections. I figure out that with the SBAS constellation OFF this does not happen anymore.
