Steps to reproduce
- Choose NTRIP client for correction source in rover mode.
- Fill out any all fields except username. Leave username empty/null.
- Save config. Choosing load yes or no has no impact on the behavior reported here.
- Inspect NTRIP client fields. NTRIP client field values get modified. For example one field value will be removed and appended/concatenated into a different field.
I verified this on both my reach units. Same behavior. It appears that only the username field yields this behavior. No other NTRIP fields left empty/null reproduced the same behavior. I have an NTRIP endpoint that requires no username, hence this workflow.
ReachView: 0.4.9
Reach image: 1.2
Initial state
After save
