greetings, I have since Friday past I have not been able to connect Ntrip caster, with the user you provide and now local Ntrip appears, but I can not use base and rover with the same internet moden since I can not be far from the same internet moden… thx
Hi Jarn,
The local NTRIP function is made for drone mapping when the base and remote drone controller are in one Wi-Fi network.
Let’s check what’s wrong with the NTRIP Caster in your case. What exactly happens when you try to connect via Caster?
