Hello all. I have an ntrip caster application and I want to testing the capabilities. The name of caster is locast.
I want to know how many base station can be served by locast.
Everyone can use this caster, it’s open caster. Everyone can use your own mountpoint name.
Thank you.
You might want to provide some additional information, to make it easy to setup for people.
Great.
Can you give an example of the credentials that we must put in order to use your caster in the reach antennas?
Sure. I’m really busy for several days past. This is the setup for using locast caster.
Base
locast.erkasenda.com
Port = 2005
Password = cors
Mountpoint = “free as you like”
Rover
User = dik
Password = dik
Hi.
Use the wifi in my house and I managed to connect without problems.
The only thing I noticed is that once I turned off the output corrections (Base mode), rover kept receiving them for several minutes.
Finally, locast achieves its purpose. Excellent work.
