I don’t get any telemetry data when making a serial connection in APM Planner 2.0. I should also say that my laptop sees the telemetry radios and in APM Planner’s 3DR setup menu I can load settings and save settings to both radios using the tty.SLAB_USBtoUART
serial option. The radio indicator lights are solid green.
Hi @kim.argayoso,
May I ask you to share the photos of your setup? Would you mind explaining what baud rate did you specify for the telemetry radios?
The baud rate I specified for telemetry radio is 57600. Here’s a sample setup photo which is the same as mine,
There is no telemetry unit on your photo?
Did you uncomment Telem2 line in
