Simple system report
app version: 2.20.8-rs2-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: 6C:21:A2:BF:78:C2
security: wpa-psk
ssid: reach:2C:F7
uuid: a393981c-fc33-4aa0-9867-c01671834ad4
base mode:
base coordinates:
accumulation: '0.2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: ntrips://209.236.40.181:2101/King_cmr#rtcm3
type: ntrips
rtcm3 messages:
'1006':
enabled: true
frequency: '0.1'
'1074':
enabled: true
frequency: '1'
'1084':
enabled: true
frequency: '1'
'1094':
enabled: true
frequency: '1'
'1124':
enabled: true
frequency: '1'
bluetooth:
discoverable: false
enabled: true
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: lawrence.rowe:***@209.236.40.181:2101/King_cmr
send position to base: 'off'
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: true
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: true
version: null
lora:
air rate: '9.11'
frequency: 868000
mode: write
output power: '20'
position output:
output1:
enabled: true
format: nmea
path: ttyGS0:57600:8:n:1:off
type: serial
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: true
galileo: true
glonass: true
gps: true
qzss: true
snr mask: '35'
update rate: '5'
