esa.attia
(Esa Attia)
August 23, 2017, 5:44am
1
Hi ,
I’m trying to interface my AR6210 spektrum receiver to the Navio2.
The receiver has NO PPM/SB outputs only PWM signals on each channel for Throttle, Ale ,elv ,Rudd etc .
Can someone point me to the documentation when I can directly plug the respective outputs from each receiver channel to the Navios RC Input pins and how do I setup the firmware to read these respective channels
Cheers
Navio2 only supports SBus/PPM RC input. The only way to use a PWM only receiver is to connect a ppm encoder between the receiver and the Navio2.
http://ardupilot.org/copter/docs/common-ppm-encoder.html
esa.attia
(Esa Attia)
August 24, 2017, 7:54am
3
Ok … I just got myself an AR7700 receiver which has a PPM output.
When I do
cd /sys/kernel/rcio/rcin
sudo cat connected
I get 1 and when I do sudo cat ch0 , ch1 I can see the channel pwm values changing.
When I run Mission planner I don’t see the green bars lit up …it is all blank .
What else can I try.
I’m running the latest raspbian image . Have done nothing fancy.
Mission planner is reporting back status from IMU / GPS etc
Cheers
Could you please make sure you made sudo update-alternatives --config arducopter
? The version for navio2 should be selected.
esa.attia
(Esa Attia)
August 24, 2017, 10:35am
5
Ok I will try this tomorrow.
Since I have a rover project
I assume it will be
sudo update-alternatives --config ardurover ?
esa.attia
(Esa Attia)
August 25, 2017, 11:50am
6
I just tried this and it all appears to be working now
