akhedr.0391
(anafenza_gse)
September 24, 2020, 5:56pm
#1
Not getting NMEA message output after firmware update of REACH m+. I updated from firmware 2.17 to 2.22 and now I am not getting any NMEA messages outputted out of the serial port. Previously I was getting all messages printed except GGA (which is a second issue) . I updated the firware in hopes to resolve this issue but now I am not seeing any messages at all.
Example of message prior to update:
Question 1: Why is the GGA message not present and how enable it ?
Question 2: Why am I not seeing any messages after update
same setup.
Thanks in advance.
Update resets everything, check your app pages.
Glad you brought this up.
@tatiana.andreeva is there a way to save your settings them load them in again after the update process?
I just updated mine after my beta tester had iPhone connection issues. I had to redo each page manually. Would be nice to reload settings.
I see this as an issue of deploying larger numbers of emlids.
Hey there,
@akhedr.0391 ,
It looks like the device has no solution status: that’s why NMEA strings are empty. Please, make sure it shows at least SIngle in the Status tab.
@PotatoFarmer ,
Usually, the firmware update should not reset the settings to default. However, the reflashing procedure indeed resets them.
It’d be great if you create a separate thread with the description of the issue. A screencast would be of much help there.
system
(system)
Closed
January 9, 2021, 8:35am
#6
