Currently using the latest Stretch Raspbian version of the OS
Been following through the instructions for installing the OS Image. It flashes to the SD card ok but when I put the SD card into the Raspberry Pi and connect it all I get is a rainbow coloured screen and no CLI and cant SSH on to the Raspberry Pi either. I have used these things a lot before but never had this problem. Any suggestions as to why the OS is not being flashed properly with Etcher?
I have the NAVIO 2 board and a Raspberry Pi 2 B (i think, been a while).
Trying this out as part of a school project between our school and two others across Europe. Goal is to build a flight controller for a drone using the Raspberry Pi.
Just tested it with a freshly downloaded version of Raspbian Stretch on the same SD card, which is new and straight out of the box, and it worked no problem.
Could it be the image from the NAVIO site is not downloading correctly and maybe has an error in it when I download it?
Clean install of the EMLID OS from their site.
Being powered by a 11.1V lipo as that will power the drone this will be a part of eventually. Does the same thing when Pi powered directly
Currently using a samsung charger which can do up to 2A output and still just the rainbow screen. Was not sure how to run the checksum to check the download but have downloaded the image a couple of times and always the same result. Surely it would be getting 2A from the lipo battery? It runs regular stretch from the battery just not the EMLID version
I just tried with mine and i get for a second or two just the same rainbow thingy before OS is lunched.
Both with lipo or 2amp usb bank.
Would look at the image and make sure its properly flashed. I assume you run latest version of etcher?
Took the image out of the xz file and checked the MD5 and it matches but when I put the img file on the SD card nothing different happens.
Is there any other way to check if the Navio I have could be causing it. Normal Stretch runs but it ignores the Navio hardware. Could that be the issue ?
