I see that the Base settings are loading in the screenshot. Does this page load so that you can add the base’s coordinates? If yes, please share an additional screenshot showing the settings.
Tried several times till I noticed that somehow after I turned base output on using the RV app on the base receiver - when I turned the correction input on on the rover those changes were actually occurring on the base. (Because the rover was not connected on the wifi even though on the app it showed / appeared connected) . When I went to check on the phone wifi I found that it was actually the base and not the rover that was connected. In other words I had made both correction input on on both base and rover
I then decided to use the browser to fix base out put and corrections input on base and rover respectively. Then I opened the app to check the changes. They were ok. But I had to wait again till suddenly I saw float. Eventually I got my fix.
I haven’t tried RV3.7.13 in the field. Will do so tomorrow. I dont know why it didnt like me or my phone
I think its all to do with the RV3 app’s recent upgrade
Thanks for sharing! Please let me know if the LoRa connection works well in your new tests with ReachView 3 7.13.
Sounds weird. Is this issue still there? I mean, do you see both receivers on the list when only the base is connected to the network? Does the rover disappear after refreshing the list?
