guido
(Guido Steijaert)
1
I complete new and learning fast at the moment. The telemetry radio does not have a heartbeat.
With Missionplanner 1.3.65 And ArduRover 3.4.2 In the Sik Radio Part I get the Local information, but no remote information.
I there a possebility to do a kind of diagnostics on the raspberry to check if the radio connected to the Navio2 board is working well?
guido
(Guido Steijaert)
4
Sorry,
Some photo’s with the asked information.
@guido,
Have you connected 5V and GND radio pins to corresponded Navio2 UART pins?
guido
(Guido Steijaert)
6
yes I did, the green led is blinking. It should be continious on to have a fix.
Is it an option to buy an usb-rs232 converter and try to connect thru USB?
guido
(Guido Steijaert)
8
@tatiana.andreeva
The Air part does not have a USB connection. I m going to get a USB-RS232 converter. Then I’m able to connect it to a PC to check the settings.
@guido,
Are you sure your radio has RS-232 output, not UART?
Could you please share the datasheet of this radio module?
@guido,
So, you’ll need USB to UART converter, not USB to RS-232. Am I missing something?
guido
(Guido Steijaert)
12
You are right. I did order the wrong one.
guido
(Guido Steijaert)
14
I did get the UART coverter. Connect everything and still no link between the radio’s.
What I did:
- connected the groundradio to my notebook and did an update of the firmware
- connected the airradio to my notebook and did an update of the firmware
- connected the airradio to the raspberry (USB)
- did change the settings from UART to USB on the raspberry
Now the radio’s pair, green led’s are solid.
But when I try to connect with missionplanner, no connection with the rover. When I connect the rover with a cable, over UDP evrything isworking well.
I think I’m close, but I miss something.
Hi @guido,
May I ask you to share the /etc/default/ardurover
file content again?
guido
(Guido Steijaert)
17
Hi @tatiana.andreeva,
Thank you for your effort. after a restart it is running well.
system
(system)
Closed
19
