Hey
We don’t see any option in kinemetic mode. Not even in adavance. Updating videos. Kindly check and revert. Thanks
Jugal
Hey
Jugal
Try to update…
Most likely the base coordinate is not entered or significantly different from reality.
it is showing coordinates perfect but accuracy level is like normal gps.
we also stopped primary gps and used only RTK gps. after sometime it started circling.
also not able to see float or fix . I will update it and try & make sure base coordinates are not different from reality.
do u see anything else what we could be missing?? thanks
if you can not see advanced settings somethings is wrong.
try to open another config file.
andreas
Please show us your base config.
Base has no coordinates.
Try with estimated coordinated for base.
