If you set an SNR mask then any satellite below it will be discarded and thus not used in solution. Reach needs at least 4 sats above mask to produce a solution.
I live at rolling hills. To get good sky view, i use 5 metres pole. Yesterday I test for post processing, I get 6mm and 1cm precision, with 5 minutes observation. I saw the SNR is high
