Question to the team Emlid. Can one add the message in NMEA: the base (co-ordinate - the position)? He relates to RTK and RTN (VRS; NTRIP ). This solution is useful to the work with external software.
Hi Pawel,
If I understand it right that you ask about NMEA PTNL, BPQ, it’s not possible to add it since it’s a Trimble proprietary message. If I got your question wrong, please elaborate on the message you need.
Hi Kseniia
Thank you for information. NMEA PTNL, BPQ this needs - you understand me well. Is the message of the message of the position of the base by the different message NMEA possible is?
NMEA WPL alternatively the non -standard message?
Hi Pawel,
There are no messages that output a base position in the official NMEA standard at the moment. So, I can hardly suggest any ready-to-use solution. However, your request is noted.
