hello
I have a reach m and a reach rs and I want to send the signal from the reach m to a tractor terminal via rs232
I have an adapter from uart to rs232
The tractor is a case puma and the display is an afs 700 pro also intelliview called.
He display need the NMEA message with gga and rmc at least.
So when I setup everything the display receive the gsv signal and show me the satellites in view, but the display can’t translate the gga to the a position.
Does someone have an idea what the problem could be ?
Our NMEA messages are in sync with the official standard, so there’re no GP messages.
We sometimes have to push these breaking changes to be compatible with more accessories and software.
So, here’s Reach NMEA messages at the moment: GNRMC, GNGGA, GPGSA, GLGSA, GAGSA, GPGSV, GLGSV, GAGSV, GNGST, GNVTG.
Reach outputs GNGGA.
If you need to change GN string from Reach to GP, the only thing I can recommend you is to output the position from Reach on 3rd-party board (Arduino or RPi), write a script that changes strings, and run it on this board.
You should set up the update rate in RTK settings to 5 Hz.
