Recently we’ve launched a completely new version of the ReachView 3 for all iOS and Android devices. If you’re new to the app, you probably need some tips on getting started. Take a look at the videos covering the basic workflows.
Connecting to Reach RS2 and RS+
Before you start working with your receivers, you need to connect them to the ReachView 3 app. The process is similar for both Reach RS+ and Reach RS2, the main difference is in the LED light indication.
Here’s the video guide describing the steps for connecting to Reach RS+:
And that’s how you connect to Reach RS2:
Creating a Survey Project
When you’re all set with the connection to Reach receivers via the app, you are ready to create your survey project and explore the new features of the survey tool. Our video guide has step-by-step instructions that you can use as a hint:
Collecting Points
Now you can start collecting points with ReachView 3. Set the antenna’s height, press the plus icon, and begin collecting the points. Our video guide describes all steps:
Exporting Data
When you finished the survey, you need to export the data from ReachView 3. Now it’s possible to manage your projects without having your receivers connected to the app. Here’s a video tutorial that will walk you through the whole process of exporting.
