New in Emlid Flow: Vertical tolerance for surface stakeout and the ability to add WMS layers directly in the app
Hi everyone!
Emlid Flow 15.14 brings two improvements to the fieldwork for users on Pro and Business plans. You can now set vertical tolerance for surface stakeout to check elevations against your project’s requirements and add WMS layers directly in Emlid Flow without returning to Emlid Flow 360.
Setting vertical tolerance for surface stakeout
Different construction stages have different tolerance requirements. Now, you can set the vertical tolerance for surface stakeout to match your project’s specifications and make elevation checks easier during construction.
Define the acceptable deviation from your design surface in Survey settings, and the stakeout plate will turn green when the measured elevation is within tolerance. This will give you immediate visual feedback on whether the elevation meets your requirements.
We’ve also changed the Fill color on the stakeout plate from gray to industry-standard blue, making it easier to identify areas where material needs to be added to reach the design elevation.
Together, these updates help you quickly identify areas that meet the design requirements and those that need further grading.
Learn more about working with surfaces in the Working with surfaces guide.
Adding WMS layers directly in Emlid Flow
Previously, you could only view layers that had already been added to a project in Emlid Flow 360. Now, you can select additional layers from your existing WMS library right in the app. This makes it easier to bring in additional map references while you’re in the field, whether you need aerial imagery, cadastral maps, or other geographic information to better understand your survey area.
To add WMS layers, open Map layers in your Emlid Flow project and select the layers you need from the available list.
The selected layers will be added to your project and become available on the map alongside your existing layers.
For detailed instructions, see Working with map layers.
To get access to the features, don’t forget to update your Emlid Flow app to version 15.14!
This is perfect, Thank you
