Hello, everyone!
I am currently doing a university project and my goal is to find the position of a rover in real time.
My set up is the following: 2x NEO M8T boards connected to a Raspberry Pi 3 (updated to latest version GNU/Linux 8).
The reason that they are both connected to the Pi is that I am not sure that my SiK telemetry transmits anything as even in RTK Navi on a laptop I don’t get base station data. (the radios are matched)
The M8Ts are set to 115000 baud rate by using u-center (latest version). NMEA messages are turned off and UBX messages are turned on.
I installed the latest version of RTKLIB from tomojitakasu’s github on the Pi. Ran make in the rtkrcv folder.
Ran chmod +x rtkstart.sh and chmod +x rtkshut.sh as it wanted permissions.
Started rtkrcv with sudo ./rtkrcv
I get “invalid option value pos-1snrmask” but the program still runs.
I run a conf file which I created but I DONT KNOW if it is correct.
It says “startup script ok” “rtk server start error” and thats it… nothing else.
The conf file I use is as following:
console-passwd =admin
console-timetype =gpst # (0:gpst,1:utc,2:jst,3:tow)
console-soltype =dms # (0:dms,1:deg,2:xyz,3:enu,4:pyl)
console-solflag =1 # (0:off,1:std+2:age/ratio/ns)
Specify connection type for Rover (1), Base (2) and Correction (3) streams
inpstr1-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
inpstr2-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
#inpstr3-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
Specify connection parameters for each stream
inpstr1-path = ttyACM0:115200:8n:1off
inpstr2-path = ttyACM1:115200:8n:1off
#inpstr3-path =
Specify data format for each stream
inpstr1-format =ubx # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
inpstr2-format =ubx # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
#inpstr3-format = # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,8:sp3)
Configure the NMEA string to send to get Base stream. Required for VRS.
inpstr2-nmeareq =off # (0:off,1:latlon,2:single)
inpstr2-nmealat =0 # (deg)
inpstr2-nmealon =0 # (deg)
Configure where to send the solutions
outstr1-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
outstr2-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
Specify here which stream contains the navigation message.
misc-navmsgsel =corr # (0:all,1:rover,1:base,2:corr)
misc-startcmd =./rtkstart.sh
misc-stopcmd =./rtkshut.sh
Set the command file to send prior to requesting stream (if required)
file-cmdfile1 =/home/pi/rtklib/app/rtkrcv/gcc/m8t.cmd
file-cmdfile2 =/home/pi/rtklib/app/rtkrcv/gcc/m8t.cmd
file-cmdfile3 =
pos1-posmode =static # (0:single,1:dgps,2:kinematic,3:static,4:movingbase,5:fixed,6:ppp-kine,7:ppp-static)
pos1-frequency =l1 # (1:l1,2:l1+l2,3:l1+l2+l5)
pos1-soltype =forward # (0:forward,1:backward,2:combined)
pos1-elmask =15 # (deg)
pos1-snrmask_L1 =0 # (dBHz)
pos1-dynamics =off # (0:off,1:on)
pos1-tidecorr =off # (0:off,1:on)
pos1-ionoopt =brdc # (0:off,1:brdc,2:sbas,3:dual-freq,4:est-stec)
pos1-tropopt =saas # (0:off,1:saas,2:sbas,3:est-ztd,4:est-ztdgrad)
pos1-sateph =brdc # (0:brdc,1:precise,2:brdc+sbas,3:brdc+ssrapc,4:brdc+ssrcom)
pos1-exclsats = # (prn …)
Set which GNSS to use. 1 is GPS only, 4 is GLONASS only. Add codes for multiple systems. Eg. (1+4)=5 is GPS+GLONASS.
pos1-navsys =7 # (1:gps+2:sbas+4:glo+8:gal+16:qzs+32:comp)
Ambiguity Resolution mode, set to continuous to obtain fixed solutions
pos2-armode =fix-and-hold # (0:off,1:continuous,2:instantaneous,3:fix-and-hold)
pos2-gloarmode =off # (0:off,1:on,2:autocal)
pos2-arthres =3
pos2-arlockcnt =0
pos2-arelmask =0 # (deg)
pos2-aroutcnt =5
pos2-arminfix =10
pos2-slipthres =0.05 # (m)
pos2-maxage =30 # (s)
pos2-rejionno =30 # (m)
pos2-niter =1
pos2-baselen =0 # (m)
pos2-basesig =0 # (m)
out-solformat =llh # (0:llh,1:xyz,2:enu,3:nmea)
out-outhead =on # (0:off,1:on)
out-outopt =off # (0:off,1:on)
out-timesys =gpst # (0:gpst,1:utc,2:jst)
out-timeform =tow # (0:tow,1:hms)
out-timendec =3
out-degform =deg # (0:deg,1:dms)
out-fieldsep =
out-height =ellipsoidal # (0:ellipsoidal,1:geodetic)
out-geoid =internal # (0:internal,1:egm96,2:egm08_2.5,3:egm08_1,4:gsi2000)
out-solstatic =all # (0:all,1:single)
out-nmeaintv1 =0 # (s)
out-nmeaintv2 =0 # (s)
out-outstat =off # (0:off,1:state,2:residual)
stats-errratio =100
stats-errphase =0.003 # (m)
stats-errphaseel =0.003 # (m)
stats-errphasebl =0 # (m/10km)
stats-errdoppler =1 # (Hz)
stats-stdbias =30 # (m)
stats-stdiono =0.03 # (m)
stats-stdtrop =0.3 # (m)
stats-prnaccelh =1 # (m/s^2)
stats-prnaccelv =0.1 # (m/s^2)
stats-prnbias =0.0001 # (m)
stats-prniono =0.001 # (m)
stats-prntrop =0.0001 # (m)
stats-clkstab =5e-12 # (s/s)
ant1-postype =llh # (0:llh,1:xyz,2:single,3:posfile,4:rinexhead,5:rtcm)
ant1-pos1 =0 # (deg|m)
ant1-pos2 =0 # (deg|m)
ant1-pos3 =0 # (m|m)
ant1-anttype =
ant1-antdele =0 # (m)
ant1-antdeln =0 # (m)
ant1-antdelu =0 # (m)
SOS!
P.S The Bold big letters are “#” commented out
