Would it be possible have a negative height input for the pole settings in the Reachview 3 app? I need this for recording depth of electricity lines. So one GPS is for the height of the ground and one for depth of the cable installed.
Hi Jónas,
Can you share a sketch or describe how you plan to record depth? Looks like I miss something, as I can’t see how a negative height will help.
I think you would have to take two shots at the same location. One shot would be with the pole height above the ground and the second would be with the pole height above the utility. Neither pole height would have to be negative unless the utility is above the pole height reference point.
Go with the principal “the higher the pole height , the lower the elevation”
