help me to find out the coordinates, I tried using PPP settings
ppp.zip (437.8 KB)
Hi @sahatmanikesri,
You can upload the log to the CSRS-PPP service by following the steps of this guide. After processing, the PPP service will send you an email. You can check the coordinates in the summary file or the PDF file from the full_output archive.
I also recommend you record longer logs for PPP: for 4 hours or more. It helps ensure the best accuracy.
