Hello, Im new to the Navio products. Can someone explain how to setup a Navio Raw board on the Raspberry Pi A+/B+ and start collecting raw data for post processing. And then i need some help in creating RINEX files.
thank you,
-Dan
thank you,
-Dan
Hello Dan,
To find out how to setup everything for logging please take a look here:
http://docs.emlid.com/Navio-dev/rtklib/
Rinex could also be created using RTKLib, as in this manual:
Let me know if you have further questions.
@igor.vereninov, thank you.
Are the Navio RAW boards still available? If no, is the Neo-6T USB Dongle the same GPS only in a different package?
thank you
-dan
BTW, My plan is for a single Rover on a vehicle.
Therefore the work flow is this
Rover station* ----> Raw Data ----> RINEX ----> GNSS Post Processing Software <---- FTP Download of Precise Ephemeris data
Output: Post-processed track logs of the vehicle
Do you see any problem here?
-dan
Navio Raw boards are not available any more, but Navio+ also outputs raw data. NEO6-T USB Dongle uses the same receiver as Navio Raw. For postprocessing dongle with RPi will do just fine.
Your workflow is definitely posssible.
