I"m working on automating post-processing in Windows of data collected on the Reach. Most specifically, I need CONVBIN and RNX2RTKP, and I need the Emlid version due to need to retrieve the time marks/reflect them in the OBS file generated, which base RTKLIB does not do.
I am running into dead ends and any help is appreciated. First off, I need version b27 (current known issues with b28 and higher means I cannot uses those versions). Secondly, even with the current version, I am running into continued challenges with trying to compile from source after trying with Embarcadero C++ Builder (current version 10.2.3), MS Visual Studio 2017, or with MinGW.
Any guidance on how to get the b27 code base, as well as known “tweaks” necessary in order to successfully compile CONVBIN for Windows in particular is greatly appreciated. Alternately, if there is a published location for the already compiled EXE’s for b27 of the Emlid version of RTKLIB CUI’s, that would be wonderful as well.
Thanks in advance for the help, and (as always), the product is awesome!
