Can someone please tell me how to fix this? Thanks
I do not know this command. (to be clear), Install apm-navio2 line is still present on some old documentation. Since the latest img (may 2018), it could be no longer in use?
Follow the Wiki: https://docs.emlid.com/navio2/common/ardupilot/configuring-raspberry-pi/
Then do
sudo apt-get update && sudo apt-get dist-upgrade
and: [https://docs.emlid.com/navio2/common/ardupilot/installation-and-running/]
(https://docs.emlid.com/navio2/common/ardupilot/installation-and-running/)
Marc
Hi @kim.argayoso,
There is no apm-navio2
package.
I’d recommend you checking links Marc posted above, these guides should help you with all the setup and configuration process.
I’ve fixed the problem already. Thanks you guys!
