Hi all,
I am using a navio2 board attached to my Pi3 and I’m wanting to use the servo rail as Gpio ports, I can export them through the method explained in the docs (echo 501 > /sys/class/gpio/export) and that works fine and I can use them through terminal but I am wanting to control these pins with a python program so I can use wait_for_edge().
When I use the RPI.GPIO library though I can’t find which pin number I should use with the configuration that library uses, as using the 501 pins like below:
Causes: ValueError: The channel sent is invalid on a Raspberry Pi
And the only mode for pins I can find seem to be BCM or BOARD which don’t support the Navio2 pin numbering method
Is there some other mode I should use to manage the servo rail within Python or is another library better suited?
Thanks for any help
