I am trying to connect the bluetooth dongle from my Pixhawk to the NAVIO2. The previously used Pixhawk connector won’t quite latch to the board, so I am switching to the NAVIO2 provided one.
I need to know the NAVIO2 board UART connector pinout (six pin) so that I can connect the four wires (+5, GND, Tx, Rx) to my bluetooth dongle.
So far I have assumed that it is the same pinout as the Pixhawk, but I would like to ensure that this is the case before powering it up. I read that the pinout was listing in the old NAVIO+ document, but I failed to find that. Also my board is now mounted, so looking at the bottom is difficult.
I was hoping to use Bluetooth instead of wi-fi – because I am already using the wi-fi to communicate with the GoPro on the same device. It is an option, but since I don’t need the range I would rather not use it.
I wasn’t sure whether it was possible to use the bluetooth on the Pi 3. I may sacrifice a bit of range (meh) by using it, but it is probably a cleaner option. I will search for the forum post on it.
