Hi.
I am doing a drone project where I want to use the Navio2 on a Raspberry Pi 3. The Navio2 should run Arducopter while the Raspberry Pi runs an Opencv script with a camera sending commands to Arducopter using DroneKit. I also want to be able to control 4 servos from the python code and get input values to the code from a limit switch (similar to this one http://www.robotshop.com/en/micro-contact-limit-switch.html) and an optical encoder. Is this possible with the Navio2/Raspberry3? The switch and encoder is what I am unsure about, is there any way to get these input values with this setup? If not, is there some kind of way to workaround this issue?
Thanks!
