I have been playing with the above setup since a couple of days, and altough for a very short time moving around the pi/navio2 sended the correct telemetry data to the android Tower setup I am using, suddenly it does not work anymore…
wifi network connection is ok, tower app is connecting properly (I even have the video streaming working) but I do not receive any sensor data as it seems… I cannot calibrate or arm,
Starting Arducopter manually gives as only message: “Raspberry Pi 2 with BCM2709!” which is strange as this is a Pi3. Some googling on this gives me the impression that this is not "abnormal"
As I did a apt-get update/upgrade dist-upgrade and I read in a couple of topics that this could cause problemens with I2C, etc I started from a fresh navio image but I still have the same issue. Any idea on how I can check what is the problem? How can I check that all the GPIO/I2C/etc stuff is working properly? The behaviour that I have, seems to be related to the interface to the sensors in one way or the other…
Thanks in advance,
