Hello, first post here.
I’m setting up my first build with a Navio2, Raspberry Pi3 and now a PiCam v2
But when I’m trying to run gstreamer on Windows, I get the following error:
WARNING: erroneous pipeline: no element “avdec_h264”
Any ideas?
Any ideas?
i might have worked out a different solution for you:
it has an very acceptabel delay and it is start and stop-able!
make sure you have netcat installed on rpi
sudo apt-get update
sudo apt-get install netcat
run on rpi: (for streaming over port 600 with a resolution of 800x600 and a bitrate of 1000000)
sudo raspivid -t 0 -w 800 -h 600 -b 1000000 -hf -ih -fps 20 -o - | sudo nc -k -l -p 600 -v
on windows pc:
install netcat (https://eternallybored.org/misc/netcat/)
install mplayer (http://mplayerwin.sourceforge.net/downloads.html)
easiest way to install to C:\netcat and C:\mplayer
run a command line
C:\netcat\nc64.exe 192.168.0.215 600 | C:\mplayer\mplayer.exe -vo direct3d -fps 35 -cache 512 -
if you install to different paths you need to adjust the path of course!
Thanks for the tip!
I have installed Ubuntu on my computer and got the exact same problem there (surprise?). However, this fixed it for me:
sudo apt-get install libopus0
sudo apt-get install gstreamer1.0-libav
Anything similar I can do in windows?
i’m not sure if i remember correctly;
i believe it was a libav issue
make sure to install full gstreamer and add the libav module from gstreamer (merge modules)
In case anyone else get the same problem:
I had not installed gstreamer correctly, make sure to install “complete” version to get all plugins installed.
