Navio2 raspberry
Can Navio2 work on raspberry pi 4? or only 2 and 3
Hi @philip.jabero24,
Navio2 can work with Raspberry Pi 4 Model B. Please check a complete list of supported boards in this guide.
thank you for the quick response,
can i ask you whats the difference between these 2
are both compatible with raspberry pi 4 or only the second one is?
thank you
As I see, the difference between them is that one package has accessories like an external antenna and power module while the other only contains Navio2. It’s the same Navio2 in both packages and should work with Raspberry Pi 4 Model B.
