I’m using PX4-emlid-navio2 with the RPi3 and want to let them communicate with the on-board mavros.
How can I do this ?
I have probably a trouble with the FCU adress given in the PX4 / or on the mavros node start :
For PX4 i do this :
mavlink start -d /dev/ttyAMA0 -b 921600 -m onboard -r 80000
INFO [mavlink] mode: Onboard, data rate: 80000 B/s on /dev/ttyAMA0 @ 921600B
For mavros i do this :
roslaunch mavros px4.launch
with following relevant lines in the px4.launch file :
is there any node in Ros using ardupilot that can directly command the PWM of the navio ?
I know the offboard mode that allows to use the actuator control node with the PX4, but that doesn’t exist with ardupilot from my point of view.
Any idea?
yes i tried that, with a delay of 2seconds.
Eventually i’m trying a costum ros node based on the navio libraries that won’t have the latency.
I will try and update response ASAP.
