I am using the Navio Power Module (This: https://store.emlid.com/product/power-module/) It’s rated voltage is in terms of Lipo batteries. It states that it’s good for 6s lipos which fully charged is ~25.2 volts. I am using 2 SLA batteries to produce a 24v system. When fully charged these are ~26.4 volts. However, the power module rating isn’t in volts so i’m a little worried about using it for this setup. Can someone confirm that it will work for this setup or simply - What is the max voltage for the Navio Power Module?
Hi @beeeeee,
You can use SLA batteries instead of LiPo, there should be no issues with it.
Navio2 power module should operate fine with voltage up to 28 V.
