Navio2 power module alternatives
Hello! I would like to know, if it is possible to use standard (pixhawk 2.4.8 or pro) power module to power Navio2. It seems like Navio power module v.2 and modern pixhawk modules are absolutely similar element-wise.(same Max current, both support up to 6S, same output, same ADC). Correct me , if i’m wrong. Even in Ardupilot we select Pixhawk to use voltage-current monitor.
Thank you.
No problem to use PixHawk compatible power module. You will have to find the small plug for the Navio side.
Thank you, Marc. :handshake:
