I installed a new firmware image emlid-raspbian-20220608.img into my Raspberry 3 and since that I have not been able to get proper data from Mavlink. Installation of the new image went fine and I can connect Navio2 with upd: from Mission Planner and also with Putty. Ardurover service is running but the issue is that the Mavlink messages that Mission Planner reads are almost all empty. Perhaps the only exception is the board voltage.
I find following error messages from the log
INFO MissionPlanner.MAVLinkInterface - 9.9.2022 17.24.29 6 Initialising APM
bps 649 loss 0 left 169 mem 85,1015625 mav2 True sign False mav1 0 mav2 30 signed 0
INFO MissionPlanner.MAVLinkInterface - 9.9.2022 17.24.30 2 Config error: Baro: unable to initialise driver
bps 736 loss 0 left 275 mem 84,205078125 mav2 True sign False mav1 0 mav2 33 signed 0
bps 620 loss 0 left 0 mem 83,4921875 mav2 True sign False mav1 0 mav2 29 signed 0
bps 388 loss 0 left 275 mem 85,54296875 mav2 True sign False mav1 0 mav2 18 signed 0
INFO MissionPlanner.MAVLinkInterface - 9.9.2022 17.24.33 2 Config error: Baro: unable to initialise driver
bps 723 loss 0 left 0 mem 84,271484375 mav2 True sign False mav1 0 mav2 32 signed 0
The Navio2 board seems to work OK and I can get for example voltage info with the Python example
I have repeated the upgrading of the image a few times, always with the same result. Could you suggest what else I can try or how to debug what is going on?
Unfortunately I fear that the real issue is a hardware failure. The MS5611 barometer is probably broken. The Barometer.py script prints constant temperature values even if I warm the sensor and the pressure is obviously all wrong
I wonder if there is some way to disable the barometer so that Ardupilot would start without it. I am running Ardurover on a boat and I do not need altitudes for my missions. Alternatively, is is possible to configure Navio2 to use an external MS5611 unit instead of the broken integrated one? The price of an external unit seems to be around 10$ so considerably less than Navio2 board.
Emlidtool seems to confirm that there is something wrong with the chip:
2022-09-12 20:53:59 navio root[743] INFO mpu9250: Passed
2022-09-12 20:53:59 navio root[743] ERROR ms5611: Failed
-- Reason: Is barometer covered with a foam?
2022-09-12 20:53:59 navio root[743] INFO adc: Passed
2022-09-12 20:53:59 navio root[743] INFO pwm: Passed
2022-09-12 20:53:59 navio root[743] INFO rcio_status_alive: Passed
2022-09-12 20:53:59 navio root[743] INFO lsm9ds1: Passed
2022-09-12 20:53:59 navio root[743] INFO gps: Passed
2022-09-12 20:53:59 navio root[743] INFO rcio_firmware: Passed
The suggestion to cover the barometer with foam is probably a standard message that is not based on analysis about how the barometer behaves. The error message remains the same with or without the foam.
If nothing else helps I think I am experienced enough for unsoldering MS5611 without burning other components. Thank you for the suggestion.
