Navio2 Maximum current throught the Servo Rail
Hello,
I would like to connect Navio2 to Raspberry 5, but Raspberry 5 requires current up to 5 Amps instead of 3 of Raspberry 4. I was wondering if it is possible supply required current through servo rail and Power connector. What is the maximum operational current of Navio2? And i would be grateful if you could highlight other possible pitfalls, incompatibilities by connection to Raspberry 5.
Thank you.
Hi Sergey,
It’s not possible to use Rasberry Pi 5 with Navio2; the software and hardware are set to be used with Raspberry Pi 2, 3, and 4.
