Does navio2 able to connect with this telemetry radio? I was just curious about the cable connection between the UART and this radio (seems like they don’t fit at all)
Hi @javinkhong,
It should work with Navio2. For UART, you need to connect 5V, RX, TX, and GND on Navio2 with the same ports on the radio (but TX with RX and vice-versa). As I see, they provide only a cable for the 6-position JST-GH connector. So, you need to get a custom cable. Still, you could use a USB connection.
