I have been playing around with the Navio2 on a RPI3. I am just testing the sensors to see how good they are and I plan on putting everything on an RC car.
I was able to test GPS and plotted the data and everything looked fine.
When I went to run the AHRS, the yaw continued to drift (assumed to be compass problem). I went through all of the posts in the forum and tried calibrating several different ways but nothing made the drift of the yaw go away. To be clear, by drift I mean when I set the module down and keep it still, the yaw keeps increasing (or decreasing).
I want to make sure I have been doing this properly. I have both a mac and a PC and have tried on both. Since this seems to be most common, this is what I did on the PC:
Remote
- ssh into pi@navio
- run APM: sudo ArduCopter-quad -A udp:192.168.1.2:14550
The raspberry pi is not mounted to anything and ArduRover does not work for me.
Local
- Open mission planner and connect.
- Go into compass calibration.
- Select primary as compass 2
- Enable automatic declination
- Only check use this compass under compass #1 and #2
- Click start in onboard mag cal and move it around until 100%
- Verify that values changed
I believe the procedure is correct, but I am not seeing any improvement with yaw. How can I fix/troubleshoot this? Any help would be highly appreciated.
