Since I’m still having issues with motors 5 & 6 calibrating and arming with the Navio2, I thought that I’d try building APM from sources on the RPi2. Following the documentation, when I enter “make navio2-hexa” I get a response of “make: *** No rule to make target ‘navio2-hexa’. Stop.”
For the hell of it, I tried “navio2-quad” with the same results. Finally I tried “make navio-hexa”, and that seemed to begin the compiling process… but I have a Navio2, so what should I do? The root problem here is that motors 5 & 6 are not calibrating and arming, so I thought that compiling from scratch would help, but I only ended up with another issue.
Is anybody running the Navio2 on a hexacopter? If so, what worked/didn’t work for you?
Sorry, I haven’t noticed your other post.I can confirm the issue. There was a bug. So thank you for reporting! The package will be updated shortly.
The source code is being worked on to be disclosed.
UPD:
The new package has been released. In this version the issue that’d been described above, should be gone.
Right on! I’ll give the new package a try later today after work. Hopefully I’ll be able to take my first test flight tomorrow morning if everything else goes well
