Had a bit of a accident today and my navio 2 board took some damage but surprisingly still works as if nothing happened. Long store short I had a major crash and my navio was covered in wet mud and is significantly bent where the uart port is as you can see from the image. It does still work with a few slight gyroscope and compass calibrations needed but should I bother bending it back or should I just leave it and not risk breaking any inner layers? I must say the emlid team sure did make one hell of a tough board I cannot believe it still works.
Hi Aryan,
It looks like it was indeed a hard flight! I’m not sure that bending it back is a good idea. You’re right: it may cause more damage. Also, please be careful with further usage.
