Hello,
i just got the Navio2 to work with the raspberry pi 3. i won’t be mounting it on a drone or anything (it’s going to be used to collect data while being mounted on a cart).
in the raspberry pi config page https://docs.emlid.com/navio2/Navio-APM/configuring-raspberry-pi/ it says that the Emlid Raspberry Image is required for the Navio2 to work. so this this version of Raspbian actually required? can’t i use the new pixl from raspbian?
after i got the code from github GitHub - emlid/Navio2: C++ and Python sensor examples for developers and tried to run
“python AccelGyroMag.py -i mpu”
i get the error in mpu9250.py on line 263 saying no such file or directory.
and a similar error when i try “python GPS.py”
am i getting this because i am not using the version of Raspbian that is recommended by you guys?
i was hoping to use the pixl os because the pi has more thing to do other than reading data from the navio.
any help would be greatly appreciated.
