Is it possible to configure navio2 RC input to a RPi3 bluetooth device?
I understand that there will be some adjustments in the baud rate for performance.
Thank you!
Thank you!
Could you please elaborate on the task? What exactly are you trying to achieve? Send /sys/kernel/rcio/rcin/chN
data via Bluetooth? Thas is indeed manageable. You’ll need to enable Bluetooth first, though.
The task is to configure bluetooth telemetry.
For example, controlling a drone with a bluetooth contoller(ps4), directly from the RPi3 bluetooth module.
It will mainly serve as a backup to 4G telemery.
