Does anyone know or test, if Navio+ is working properly, mounted vertically? What are the drawbacks of having Navio+ not laid flat, but sitting top on the long PCB side?
@seaowl Should work fine, just make sure to set the board orientation in parameters:
http://copter.ardupilot.com/wiki/arducopter-parameters/#board_orientation_ahrs_orientation
The only issue I could foresee is vibration related if its on a copter, make sure how ever you mount it that the weight is evenly distributed across whatever you are using to dampen vibrations. You don’t want to have an excess of weight in one direction as this will exacerbate whatever vibrations you do have. If this is for something else like a rover or plane you should be fine.
