Is it possible to run the Navio 2 with another Pi hat such as a GSM hat such as this one
By using this method
It’s possible, but it will be tricky to get right. You should carefully look into this diagram to deduce if no pins between hats are shared. Either way, a USB solution will be way easier.
Thank you for the answer sir
