Hello friend I want to send rc channel values to Navio 2 utilizing Mavlink,I have no knowledge about Navio 2.Can I send following code directly or what are the modification which I need to do, thanks a lot
def set_rc_channel_pwm(id, pwm=1500):
“”" Set RC channel pwm value
Args:
id (TYPE): Channel ID
pwm (int, optional): Channel pwm value 1100-1900
if id < 1:
print(“Channel does not exist.”)
return
# We only have 8 channels
# https://mavlink.io/en/messages/common.html#RC_CHANNELS_OVERRIDE
if id < 9:
rc_channel_values = [65535 for _ in range(8)]
rc_channel_values[id - 1] = pwm
master.mav.rc_channels_override_send(
master.target_system, # target_system
master.target_component, # target_component
*rc_channel_values) # RC channel list, in microseconds.
Do I understand correctly that you’ve managed to resolve this issue? In this case, may I ask you to share the solution for other users with the same question?
No I cant this problem.I only ask two questions
1-Can I sent rc channel values to navio 2 from computer or pi
2-Can I sent rc channel values inside navio 2 without using any other devicw
I’ve definitely used this functionality when porting my fork of the github project Ardupilot/MAVProxy to use a different joystick library. I had to edit the default MAVProxy code to support more than 8 channels. You may also need to change firmware parameters on the Navio2 to support reception of RC override (I have PX4 firmware running on my Navio2 RPi and I had to change COM_RC_IN_MODE – Ardupilot might have something similar).
Why would you want to do this directly on the Navio2 RPi?
We hardly can provide you with a ready solution, however, it should be possible to implement. I’d recommend following @bliptrip’s advice on using RC override to accomplish this.
