Hello George,
I think I found the problem but I don t know how to solve it!
The Navio2 it doesn t work with more then 2 servos connected to the servo rail…
EX: - throttle + elevator + yaw …it works
- throttle + elevator + elerons … not work (plus 1 servo because elerons channel needed 2 servos)
- throttle + elerons …it works
- throttle + elerons + something else …doesn t work…
Maybe it is because the BEC?? It is setted to have 5 V output …I measure the voltage on the BEC and I have 5.09 V.
Should I put 6 V output on the BEC ??
The conclusion is that NAVIO2 freeze when I connect more than 2 servos to the servo rail!
I am waiting for your advice! Thank you!
