I’m using Raspberry Pi 3 and Navio 2 for a real time drone project where the latency is a major concern. I wanted to use Fully Preemptible Kernel on Emlid image, but there does not seem to be any real-time patch for version 4.4.36 (Is the kernel source code here?). So I started with a stock Raspbian 4.4.50.
I found this rcio-dkms repository which seems to be the drivers for Navio 2. I cross-compiled it and it installed fine. Using lsmod I can see the rcio_core and rcio_spi are running. However, when I start PX4 the PWM is not working properly.
ERROR [linux_pwm_out] PWM period failed
ERROR [linux_pwm_out] PWM: Failed to open duty_cycle.
ERROR [linux_pwm_out] PWM output init failed
The Raspbian I’m using is Linux raspbian 4.4.50-rt63-v7+ #2 SMP PREEMPT. I want to know if I’m doing anything wrong or installing this module is not enough to make Navio 2 run on raspbian? This is my first time compiling a driver for linux, any help would be appreciated.
Or if anyone can tell me how to enable Fully Preemptible Kernel on Emlid image 4.4.36-a7765e7-emlid-v7+ #41 would be awesome as well.
Thank you.
Update:
I just compiled the emlid-stable-4.4 kernel from source, this does not seem to have drivers for Navio 2 as well?
Unfortunately, I’m still trying to figure this out.
Basically, I think there are two choices. I can try to make the drivers work on a customized RT patched raspbian. However, the rcio-dkms I found on emlid github repository does not seem to work well. The following shows when inspecting with dmesg
rcio spi1.0: rcio_gpio: GPIO is not supported on this firmware
rcio spi1.0: rcio_pwm: Error in pwm running count
My second choice is to patch a Emlid raspbian or just configure it to be fully-preemptible. But the source code in github seems to be outdated and does not have drivers either.
I’m currently looking for some possible user-space drivers. Do you have any better suggestions? Thank you very much.
update:
I was able to upgrade emlidtool to 1.0.7 and updated the rcio firmware successfully. After using insmod for the two kernel module (rcio_core.ko, rcio_spi.ko) built from rcio-dkms, the emlidtool shows all parts run successful.
emlidtool version: 1.0.7
Vendor: Emlid Limited
Product: Navio 2
Issue: Emlid 2017-03-23 5e28de2c424cadfb61a62b88e9c0af98a6d25545
Kernel: 4.4.36-rt49-emlid-v7+
RCIO firmware: 0xfd610bbf
2018-08-14 02:12:12 raspbian root[1040] INFO adc: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO pwm: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO rcio_status_alive: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO lsm9ds1: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO gps: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO mpu9250: Passed
2018-08-14 02:12:12 raspbian root[1040] INFO ms5611: Passed
However, when using PX4, I’m still getting errors
ERROR [linux_pwm_out] PWM enable failed
The Servo example in /Navio2/C++/Examples/Servo doesn’t run either. Can't init channel 0
It’s not an easy task and it requires a lot of work and maybe some additional research. I hardly can provide you with a detailed description of all step-by-step actions, however, I recommend you to try to repeat it with our 4.14 RPi firmware.
Please try to follow this steps with 4.14 firmware:
apply RT patch to it;
cross compile rcio-dkms against the kernel by setting KERNEL_SOURCE(?)=<path to kernel>.
I finally solved the issue. For kernel 4.14, the latest version of rcio-dkms works well.
However, for older kernels, older drivers are needed. Specifically for kernel 4.4, I choose to use v0.8.3 as v0.6.5 does not even compile on Emlid provided image. I didn’t find a preempt patch specifically for 4.4.36, but patch for 4.4.38 seems to work. After installing the v0.8.3 rcio-dkms, the emlidtools still complains that pwm failed. But both Navio2 example code and px4 runs fine.
