Hello friends ı use this code to arm and take off my drone
def arm_and_takeoff(aTargetAltitude):
‘’‘while not vehicle.is_armable:
print(“Waiting for vehicle to become armable”)
time.sleep(1)
#Switch vehicle to GUIDED mode and wait for change
vehicle.mode = VehicleMode("GUIDED")
while vehicle.mode!="GUIDED":
print("Waiting for vehicle to enter GUIDED mode")
time.sleep(1)
#Arm vehicle once GUIDED mode is confirmed
vehicle.armed=True
while vehicle.armed==False:
print("Waiting for vehicle to become armed.")
time.sleep(1)
vehicle.simple_takeoff(aTargetAltitude)
I disable some pre arm check feature (GPS and RC).Because I dont have
Hello ,
Firstly I use ARMING_CHECK=0 command.I see that current altitude values from screen.When I measure the output pin voltage that enter esc,I can not see any voltage,Do you think Can I perform system without rc controller,esc … .At the moment I dont have any equipments.I have only navio 2,I have to see voltage on the output pin so
I want to disable all of pre arm check
Hi I use servo rail utilizing raspberry pi 5v pin and I also measured output servo rail pins.These are 5v and I used servo.py example.Servo motor runs properly.
