Hey,
I have a first model of Navio Raw on my Raspberry Pi B, Can I Use Navio Raw on a new Raspberry Pi 2 Model B?. Raspberry Pi 2 Model B has 40 pins, so i don’t know if is possible because RPi B has 26 pins.
I have a Navio on a RPi B+ and it works fine. The GPIO pinout for the first 26 pins is identical between
B, B+ and the RPi2.The only thing is the RPis display connector which collides with the servo pins of the Navio. If you push the Navio all the way down on the GPIO pins, it is not perfectly parallel to the RPI.
RPI2 and B+
Thanks!
