Hello, is this project still alive? Saw some great things here, learned a lot. Thank you for sharing.
Hi, it is still working, but Iāve not developed it any further. It is just a āproof of conceptā.
Did you run a speed test at all? Iām having issues but Iām only getting 4mb/s upload speed on my 4G and wondering if thatās the issue
What type of joystick do you use? I wanted to use game joystick, but control sticks are springed, so you always should apply some effort to keep throttle constant.
Links dont work!!
Can you update them please?
Hello Ole,
Your little app is pretty spiffy!
Were you intending to let others use your server?
-Austen
Hello pls give your python code on commu
nity
How do you control the drone with a joystick?
The link no longer works.
Thanks
Thanks Oleā¦ Im using your App to connect to my raspberry and stream the video. But i cant test all function , in fact i donĀ“t have the HTTP API to send command. So, can you share your API ? I already have some platform running in Azure Cloud, So i can improve your API to work with Auth of device, to others users can use, or maybe have a system ADHOC . Have some solution like Pitunnel.com solution to tunnel PI X PC connection. I appreciate to continue your effort to make these solution, a worldwide solution. Thanks
This is super awesome!! Nice work, can you share the code (private is fine too). I am debating overhauling my platform from Pixhawk series to Navio & wanna see what iām getting into!
Thanks!
Johnny
